TwinTurbo.NET: Nissan 300ZX forum - Clarification, and "jumper"
Subject Clarification, and "jumper"
Posted by BIGTSZ on July 25, 2002 at 1:25 PM
  This message has been viewed 283 times.
In Reply To Re: Foglight wiring question... posted by RezidentEvil on July 25, 2002 at 10:18 AM
Message So, in essence, I'm going to bypass the fog-light relay?
I find the power wire going to the fog light relay, cut it off before it gets to the relay (under the box), and splice it into the big white 12 volt wire.
And when you say "jumper" between the two wires, that just means I'm going to cut away some of the shielding on the two wires and run a wire between them, right? Then reinstall everything as it was before?
Thanks, sounds easy enough, I'll probably try this tonight. Lastly, should I need to disconnect the negative battery terminal before splicing these wires?
Travis
